[postgis-devel] [PostGIS] #1177: Error opening shared liblwgeom-2.0.0SVN.so
PostGIS trac at osgeo.org
Mon Aug 29 14:58:18 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  1.5.X
 Keywords:             |
 try-ing make check on postgis-svn I see some errors.
 on RedHat Enterprise ES 6 - 64bit
  PostgreSQL 9.1rc1 on x86_64-unknown-linux-gnu, compiled by gcc (GCC)
 4.4.5 20110214 (Red Hat 4.4.5-6), 64-bit
  Postgis 2.0.0SVN - 2011-08-29 23:47:45
    GEOS: 3.4.0dev-CAPI-1.8.0
    PROJ: Rel. 4.7.1, 23 September 2009
 Running tests
  loader/Point. failed ( wkt test: running shp2pgsql:
 /tmp/pgis_reg_24342/loader.err)
  loader/PointM. failed ( wkt test: running shp2pgsql:
  loader/PointZ. failed ( wkt test: running shp2pgsql:
  loader/MultiPoint. failed ( wkt test: running shp2pgsql:
  loader/MultiPointM. failed ( wkt test: running shp2pgsql:
  loader/MultiPointZ. failed ( wkt test: running shp2pgsql:
  loader/Arc. failed ( wkt test: running shp2pgsql:
  loader/ArcM. failed ( wkt test: running shp2pgsql:
  loader/ArcZ. failed ( wkt test: running shp2pgsql:
  loader/Polygon. failed ( wkt test: running shp2pgsql:
  loader/PolygonM. failed ( wkt test: running shp2pgsql:
  loader/PolygonZ. failed ( wkt test: running shp2pgsql:
  loader/TSTPolygon. failed ( wkt test: running shp2pgsql:
  loader/TSIPolygon. failed ( wkt test: running shp2pgsql:
  loader/TSTIPolygon. failed ( wkt test: running shp2pgsql:
  loader/PointWithSchema.. failed ( wkb test: running shp2pgsql:
  loader/NoTransPoint. failed ( wkt test: running shp2pgsql:
  loader/NotReallyMultiPoint. failed ( wkt test: running shp2pgsql:
  loader/MultiToSinglePoint. failed ( wkt test: running shp2pgsql:
  loader/ReprojectPts.. failed ( wkt test: running shp2pgsql:
  loader/ReprojectPtsGeog.. failed ( wkt test: running shp2pgsql:
  loader/Latin1. failed ( wkb test: running shp2pgsql:
  regress. ok
  regress_index. ok
  regress_index_nulls. ok
  lwgeom_regress. ok
 I attach the log to this ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1177>
