[postgis-devel] [PostGIS] #1382: Some addresses take a long time to geocode or normalize
trac at osgeo.org
Sat Dec 17 19:29:00 PST 2011
Reporter: raviada | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by raviada):
Regina, I upgraded to the new build which is Revision 8450. the output
from postgis_full_version is "POSTGIS="2.0.0SVN" GEOS="3.2.2-CAPI-1.6.2"
PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS"
Also I see --$Id: normalize_address.sql 8252 2011-11-29 08:49:06Z robe $-
in normalize_address function.
select geocode('2601 24TH AVE, ASTORIA, NY 111022337'); returns two rows
Total query runtime: 20943 ms.
2 rows retrieved.
"("(,,24th,Ave,,,""New
York"",NY,11204,t)",0101000020AD10000036CF279D807E52C0511C69D0424E4440,21)"
York"",NY,11214,t)",0101000020AD100000FA12A7B3417F52C0699E6C55CF4C4440,21)"
I think it is still a problem in using the geocode function. normalize
function is now returning real fast, in 30-60 ms. Geococe is the one
taking 20 secs. All NY addresses are like this.
Thanks
Ravi Ada
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1382#comment:6>
