[postgis-devel] [PostGIS] #1382: Some addresses take a long time to geocode or normalize
trac at osgeo.org
Sat Dec 17 19:35:51 PST 2011
Reporter: raviada | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by raviada):
select geocode_address(normalize_address('2734 21ST ST, ASTORIA, NY
111023653'),1)
"("(2734,E,21st,St,,,""New
York"",NY,11235,t)",0101000020AD100000097F608BA97C52C06D6463B6F24A4440,13)"
"("(2734,,21st,St,,,""Niagara
Falls"",NY,14305,t)",0101000020AD100000625E1B7D62C253C06AD712AC798E4540,17)"
"("(,,21st,St,,,Troy,NY,12180,t)",0101000020AD100000AA30B0E8D16A52C09CD542B2EC5E4540,18)"
NOTICE: Bad zip newzip range: '{}'
NOTICE: Ignore new zip range that is bad too: '{}'
NOTICE: Zip range based on only considering city: '{}'
NOTICE: stmt: WITH a AS
( SELECT *
FROM (SELECT f.*, ad.side, ad.zip, ad.fromhn, ad.tohn,
RANK() OVER(ORDER BY
diff_zip(ad.zip,'111023653') + CASE WHEN lower(f.name) = lower('21ST')
THEN 0 ELSE levenshtein_ignore_case(f.name, lower('21ST') ) END +
levenshtein_ignore_case(f.fullname, lower('21ST' || ' ' ||
COALESCE('St','')) )
+ CASE WHEN
(greatest_hn(ad.fromhn,ad.tohn) % 2)::integer = ('2734' % 2)::integer THEN
0 ELSE 1 END
+ CASE WHEN
'2734'::integer BETWEEN least_hn(ad.fromhn,ad.tohn) AND
greatest_hn(ad.fromhn, ad.tohn)
THEN 0 ELSE 4 END
+ CASE WHEN
lower('St') = lower(f.suftypabrv) OR lower('St') = lower(f.pretypabrv)
THEN 0 ELSE 1 END
rate_attributes(NULL, f.predirabrv, '21ST', f.name , 'St',
suftypabrv , NULL, sufdirabrv, prequalabr)
As rank
FROM featnames As f INNER JOIN addr As ad
ON (f.tlid = ad.tlid)
WHERE '36' = f.statefp AND '36' = ad.statefp
AND lower(f.name) = lower('21ST') AND (
ad.zip = ANY('{}'::varchar[]) ) ) AS foo ORDER BY rank LIMIT 3 )
SELECT * FROM (
SELECT DISTINCT ON (sub.predirabrv,sub.fename,COALESCE(sub.suftypabrv,
sub.pretypabrv) ,sub.sufdirabrv,sub.place,s.stusps,sub.zip)
sub.predirabrv as fedirp, sub.fename, COALESCE(sub.suftypabrv,
sub.pretypabrv) as fetype, sub.sufdirabrv as fedirs, sub.place ,
s.stusps as state, sub.zip as zip, interpolate_from_address('2734',
sub.fromhn, sub.tohn, sub.the_geom, sub.side) as address_geom,
sub.sub_rating + least(coalesce(diff_zip('111023653' , sub.zip),0),
10)::integer + coalesce(levenshtein_ignore_case('ASTORIA', sub.place),5)
as sub_rating, sub.exact_address as exact_address, sub.tohn, sub.fromhn
FROM ( SELECT tlid, predirabrv, COALESCE(b.prequalabr || ' ','' ) ||
b.name As fename, suftypabrv, sufdirabrv, fromhn, tohn,
side, zip, rate_attributes(NULL, predirabrv,
'21ST', b.name , 'St', suftypabrv , NULL, sufdirabrv, prequalabr) +
CASE WHEN '2734'::integer IS NULL OR b.fromhn IS NULL THEN 20
WHEN '2734'::integer >= least_hn(b.fromhn, b.tohn) AND
'2734'::integer <= greatest_hn(b.fromhn,b.tohn) AND
('2734'::integer % 2) = (to_number(b.fromhn,'99999999') % 2)::integer
THEN 0 WHEN '2734'::integer >= least_hn(b.fromhn,b.tohn)
AND '2734'::integer <= greatest_hn(b.fromhn,b.tohn) THEN 2
ELSE ((1.0 -
(least_hn('2734'::text,least_hn(b.fromhn,b.tohn)::text)::numeric /
(greatest(1,greatest_hn('2734'::text,greatest_hn(b.fromhn,b.tohn)::text)))
)) * 5)::integer + 5 END as sub_rating,'2734'::integer >=
least_hn(b.fromhn,b.tohn) AND '2734'::integer <=
greatest_hn(b.fromhn,b.tohn) AND ('2734' %
2)::numeric::integer = (to_number(b.fromhn,'99999999') % 2) as
exact_address, b.name, b.prequalabr, b.pretypabrv, b.tfidr, b.tfidl,
b.the_geom, b.place FROM
(SELECT a.tlid, a.fullname, a.name, a.predirabrv,
a.suftypabrv, a.sufdirabrv, a.prequalabr, a.pretypabrv,
b.the_geom, tfidr, tfidl,
a.side ,
a.fromhn,
a.tohn,
a.zip,
p.name as place
FROM a INNER JOIN edges As b ON (a.statefp = b.statefp
AND a.tlid = b.tlid )
INNER JOIN faces AS f ON ('36' = f.statefp AND (
(b.tfidl = f.tfid AND a.side = 'L') OR (b.tfidr = f.tfid AND a.side = 'R'
INNER JOIN place p ON ('36' = p.statefp AND f.placefp
= p.placefp )
WHERE a.statefp = '36' AND b.statefp = '36'
) As b
ORDER BY 10 , 11 DESC
LIMIT 20
) AS sub
JOIN state s ON ('36' = s.statefp)
ORDER BY 1,2,3,4,5,6,7,9
LIMIT 20) As foo ORDER BY sub_rating, exact_address DESC LIMIT
1
NOTICE: SELECT DISTINCT ON
(sub.predirabrv,sub.fename,COALESCE(sub.suftypabrv, sub.pretypabrv)
,sub.sufdirabrv,coalesce(p.name,zip.city,cs.name,co.name),s.stusps,sub.zip)
coalesce(p.name,zip.city,cs.name,co.name)::varchar as place, s.stusps
as state, sub.zip as zip, interpolate_from_address($1, sub.fromhn,
sub.tohn, e.the_geom, sub.side) as address_geom, sub.sub_rating +
least((coalesce(diff_zip($7 , sub.zip),0) *1.00/2)::integer,
coalesce(levenshtein_ignore_case($7, sub.zip),0) ) +
coalesce(least(levenshtein_ignore_case($3,
coalesce(p.name,zip.city,cs.name,co.name)), levenshtein_ignore_case($3,
coalesce(cs.name,co.name))),5) as sub_rating, sub.exact_address as
exact_address FROM ( SELECT a.tlid, predirabrv, COALESCE(a.prequalabr ||
' ','' ) || a.name As fename, suftypabrv, sufdirabrv, fromhn, tohn,
side, a.statefp, zip, rate_attributes($5,
a.predirabrv, $2, a.name , $4, a.suftypabrv , $6, a.sufdirabrv,
a.prequalabr) + CASE WHEN $1::integer IS NULL OR b.fromhn IS
NULL THEN 20 WHEN $1::integer >= least_hn(b.fromhn, b.tohn)
AND $1::integer <= greatest_hn(b.fromhn,b.tohn) AND
($1::integer % 2) = (to_number(b.fromhn,'99999999') % 2)::integer
THEN 0 WHEN $1::integer >= least_hn(b.fromhn,b.tohn) AND
$1::integer <= greatest_hn(b.fromhn,b.tohn) THEN 2 ELSE
((1.0 - (least_hn($1::text,least_hn(b.fromhn,b.tohn)::text)::numeric /
greatest(1,greatest_hn($1::text,greatest_hn(b.fromhn,b.tohn)::text)))) *
5)::integer + 5 END as sub_rating,$1::integer >=
least_hn(b.fromhn,b.tohn) AND $1::integer <=
greatest_hn(b.fromhn,b.tohn) AND ($1 % 2)::numeric::integer =
(to_number(b.fromhn,'99999999') % 2) as exact_address, a.name,
a.prequalabr, a.pretypabrv FROM featnames a join addr b ON (a.tlid =
b.tlid AND a.statefp = b.statefp ) WHERE a.statefp = '36' AND
a.mtfcc LIKE 'S%' AND ( soundex($2) = soundex(a.name) OR (
(length($2) > 15 or (length($2) > 7 AND a.prequalabr > '') ) AND
lower(a.fullname) LIKE lower(substring($2,1,15)) || '%' ) OR
numeric_streets_equal($2, a.name) ) ORDER BY 11 LIMIT 20 ) AS sub
JOIN edges e ON ('36' = e.statefp AND sub.tlid = e.tlid AND e.mtfcc LIKE
'S%' ) JOIN state s ON ('36' = s.statefp) JOIN faces f ON ('36' =
f.statefp AND (e.tfidl = f.tfid OR e.tfidr = f.tfid)) LEFT JOIN
zip_lookup_base zip ON (sub.zip = zip.zip AND zip.statefp='36') LEFT JOIN
place p ON ('36' = p.statefp AND f.placefp = p.placefp) LEFT JOIN county
co ON ('36' = co.statefp AND f.countyfp = co.countyfp) LEFT JOIN cousub
cs ON ('36' = cs.statefp AND cs.cosbidfp = sub.statefp || co.countyfp ||
f.cousubfp) WHERE ( (sub.side = 'L' and e.tfidl = f.tfid) OR (sub.side =
'R' and e.tfidr = f.tfid) ) ORDER BY 1,2,3,4,5,6,7,9 LIMIT 10
NOTICE: PREPARE query_base_geo(integer,
varchar,varchar,varchar,varchar,varchar,varchar,geometry) As SELECT
sub.pretypabrv)
NOTICE: EXECUTE
query_base_geo(2734,'21ST','ASTORIA','St',NULL,NULL,'111023653',NULL);
NOTICE: DEALLOCATE query_base_geo;
Total query runtime: 14172 ms.
3 rows retrieved.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1382#comment:7>
