[postgis-devel] "userland" schema in raster regression tests
Sandro Santilli
strk at keybit.net
Sun Dec 18 14:46:42 PST 2011
I've committed r8455 to fix "make check" on my system:
http://trac.osgeo.org/postgis/changeset/8455
The problem was that the test was expecting rasters
being installed in a "userland" schema, or so I understood.
But I saw no mention of any "userland" literal value in the
sql files so there must be some external setting making
that schema populated for whoever wrote the test (dustymugs?).
Now, this mail is to ask _if_ "make check" really worked
for others, and if so to figure out _why_ as it would be
a bug in the "run_test" script to be fooled by user settings.
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
