[postgis-devel] "userland" schema in raster regression tests
dustymugs
dustymugs at gmail.com
Sun Dec 18 15:23:26 PST 2011
Oops! I'll fix that once I get to a computer.
Stupid use of SELECT * on my part.
-bborie
-bborie
-----Original Message-----
Sender: postgis-devel-bounces at postgis.refractions.net
Date: Sun, 18 Dec 2011 23:46:42
To: <postgis-devel at postgis.refractions.net>
Reply-To: PostGIS Development Discussion
Subject: [postgis-devel] "userland" schema in raster regression tests
I've committed r8455 to fix "make check" on my system:
http://trac.osgeo.org/postgis/changeset/8455
The problem was that the test was expecting rasters
being installed in a "userland" schema, or so I understood.
But I saw no mention of any "userland" literal value in the
sql files so there must be some external setting making
that schema populated for whoever wrote the test (dustymugs?).
Now, this mail is to ask _if_ "make check" really worked
for others, and if so to figure out _why_ as it would be
a bug in the "run_test" script to be fooled by user settings.
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
