[postgis-devel] "userland" schema in raster regression tests
Sandro Santilli
strk at keybit.net
Sun Dec 18 23:48:48 PST 2011
On Sun, Dec 18, 2011 at 11:23:26PM +0000, dustymugs wrote:
On Sun, 18 Dec 2011 23:46:42 Sandro Santilli <strk at keybit.net> wrote:
> > But I saw no mention of any "userland" literal value in the
> > sql files so there must be some external setting making
> > that schema populated for whoever wrote the test (dustymugs?).
> > Now, this mail is to ask _if_ "make check" really worked
> > for others, and if so to figure out _why_ as it would be
> > a bug in the "run_test" script to be fooled by user settings.
> Stupid use of SELECT * on my part.
I'm mainly interested in a "run_test" bug if any.
Did "make check" work for you ?
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
