[postgis-devel] Hard upgrade process rewritten, ready for test
Sandro Santilli
strk at keybit.net
Mon Dec 19 04:38:30 PST 2011
I've committed a rewrite of the HARD UPGRADE process description to
take the "quiet" path of using postgis_restore.pl.
It may take some time before it is visible online [1] but you can generate
the manual offline using "make docs" from top-level dir (the manual would
then be accessible as doc/html/postgis.html).
I guess a call-for-test for -users would best be done closer to RC so that
we have a chance to update the list of "PostGIS objects" hard-coded into
the postgis_restore.pl script, but for the time being any review of the
text and process is welcome from developers.
Mind you: today I've added another couple of bits: fixup of SRIDs in
topology.topology (-1 vs. 0) and fixup of spatial_ref_sys (dump won't
override existing entries but non-existing entries will be restored).
[1] http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#hard_upgrade
Happy dumping and restoring !
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
