[postgis-devel] [PostGIS] #1387: Add Bborie to Hudson mail
trac at osgeo.org
Mon Dec 19 10:53:47 PST 2011
Reporter: robe | Owner: chodgson
Type: defect | Status: closed
Priority: medium | Milestone: Management 1.0
Component: management | Version: trunk
Resolution: fixed | Keywords:
Changes (by chodgson):
* status: new => closed
* resolution: => fixed
Comment:
I've put dustymugs' e-mail into hudson. I don't believe that the failure
to send dustymugs an e-mail is being called a failure - it only sends
direct e-mails AFTER it has determined there was a failure in the build.
There was a regression issue in the tickets unit test, when I looked at
it. It might be resolved now. The regression tests (against older versions
of postgres) get kicked off after every commit so it should send a message
if there are still issues after the next commit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1387#comment:4>
