[postgis-devel] [PostGIS] #1066: [raster] raster crashes server with arbitrary tests
trac at osgeo.org
Wed Dec 21 06:57:26 PST 2011
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords:
Comment(by dustymugs):
robe,
Can you try your garden tests using PostgreSQL 9.1 after creating a
"crashdumps" directory in your cluster data directory? I'm hoping that a
dumpfile is generated. Refer to section 15.7.5.1 of the following link.
[http://www.postgresql.org/docs/9.1/interactive/installation-platform-
notes.html#INSTALLATION-NOTES-MINGW]
Assuming a dumpfile is generated, please attach to ticket. Assuming this
works, this might be of significant help debugging Windows crashes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1066#comment:14>
