[postgis-devel] [PostGIS] #1397: regress test uninstall scripts
PostGIS trac at osgeo.org
Wed Dec 21 08:44:58 PST 2011
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 1) Install of postgis without any adding of postgis specific user objects
 (e.g geometry tables, raster tables)
 when you uninstall should result in  database with same number of
 functions, operators, casts, etc as what you had before postgis install
 2) Uninstall on a postgis enabled database that has postgis specific user
 data (e.g. geometry tables / raster tables / user views using postgis
 etc.) should fail.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1397>
