[postgis-devel] [PostGIS] #301: [raster] Add uninstall_rtpostgis.sql machinery
trac at osgeo.org
Sat Dec 24 02:01:58 PST 2011
Reporter: mloskot | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
With r8553 the work here is completed.
uninstall_rtpostgis.sql will be created by reading rtpostgis.sql
the run_test script (used by "make check") will test raster uninstall.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/301#comment:19>
