[postgis-devel] Fwd: Build failed in Hudson: PostGIS-trunk-regression #1772
Sandro Santilli strk at keybit.net
Wed Dec 21 14:37:58 PST 2011
On Wed, Dec 21, 2011 at 02:20:13PM -0800, Chris Hodgson wrote:
> Anyone know what the file "test_62_out" is? Something is outputting
> it from the regression tests and then the hudson buildbot script
> greps all the output files for "error" and finds it in the file,
> thus declaring the build failed, for every build in a little while
> now (perhaps the last week?)
Expecting an ERROR is not a failure (if the ERROR is obtained).
The only real failure is when "make check" returns non-zero.
I guess we could give better names to log files, anyway.
--strk;
  ,------o-.
  |   __/  |    Thank you for PostGIS-2.0 Topology !
  |  / 2.0 |    http://www.pledgebank.com/postgistopology
  `-o------'
