[postgis-devel] [PostGIS] #1235: cast to unknown-srid typmod fails
trac at osgeo.org
Thu Dec 22 16:41:35 PST 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
For clarification:
Recall we said that not specifying an srid (or using the unknonw one 0) is
the same as allowing any srids?
So what you have should in theory be the same as
SELECT geom:geometry('multipolygon');
That would keep the same srid as it had before -- namely 4326 in this
case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1235#comment:3>
