[postgis-devel] build problems on CENTOS 6.2
Nathaniel Clay clay.nathaniel at gmail.com
Thu Dec 22 16:52:34 PST 2011
Hi all,
Having trouble building postgis svn on my machine. Here is the output from
make..
for s in liblwgeom libpgcommon regress postgis loader utils raster
topology; do \
        echo "---- Making all in ${s}"; \
        make -C ${s} all || exit 1; \
    done;
---- Making all in liblwgeom
make[1]: Entering directory `/home/nathan/code/postgis/liblwgeom'
/bin/sh ../libtool --tag=CC --mode=link gcc -rpath /usr/local/lib
stringbuffer.lo measures.lo measures3d.lo box2d.lo ptarray.lo lwgeom_api.lo
lwgeom.lo lwpoint.lo lwline.lo lwpoly.lo lwtriangle.lo lwmpoint.lo
lwmline.lo lwmpoly.lo lwcollection.lo lwcircstring.lo lwcompound.lo
lwcurvepoly.lo lwmcurve.lo lwmsurface.lo lwpsurface.lo lwtin.lo
lwout_wkb.lo lwin_wkb.lo lwout_wkt.lo lwin_wkt_parse.lo lwin_wkt_lex.lo
lwin_wkt.lo lwutil.lo lwhomogenize.lo lwalgorithm.lo lwsegmentize.lo
lwprint.lo vsprintf.lo g_box.lo g_serialized.lo g_util.lo lwgeodetic.lo
lwtree.lo libtgeom.lo lwout_gml.lo lwout_kml.lo lwout_geojson.lo
lwout_svg.lo lwout_x3d.lo lwgeom_geos.lo lwgeom_geos_clean.lo
lwgeom_geos_node.lo lwgeom_geos_split.lo lwgeom_transform.lo lwspheroid.lo
-release 2.0.0SVN -L/usr/lib64 -lgeos_c  -lproj -o liblwgeom.la
libtool: link: rm -fr  .libs/liblwgeom-2.0.0SVN.so .libs/liblwgeom.a .libs/
liblwgeom.la .libs/liblwgeom.lai .libs/liblwgeom.so
libtool: link: gcc -shared  .libs/stringbuffer.o .libs/measures.o
.libs/measures3d.o .libs/box2d.o .libs/ptarray.o .libs/lwgeom_api.o
.libs/lwgeom.o .libs/lwpoint.o .libs/lwline.o .libs/lwpoly.o
.libs/lwtriangle.o .libs/lwmpoint.o .libs/lwmline.o .libs/lwmpoly.o
.libs/lwcollection.o .libs/lwcircstring.o .libs/lwcompound.o
.libs/lwcurvepoly.o .libs/lwmcurve.o .libs/lwmsurface.o .libs/lwpsurface.o
.libs/lwtin.o .libs/lwout_wkb.o .libs/lwin_wkb.o .libs/lwout_wkt.o
.libs/lwin_wkt_parse.o .libs/lwin_wkt_lex.o .libs/lwin_wkt.o .libs/lwutil.o
.libs/lwhomogenize.o .libs/lwalgorithm.o .libs/lwsegmentize.o
.libs/lwprint.o .libs/vsprintf.o .libs/g_box.o .libs/g_serialized.o
.libs/g_util.o .libs/lwgeodetic.o .libs/lwtree.o .libs/libtgeom.o
.libs/lwout_gml.o .libs/lwout_kml.o .libs/lwout_geojson.o .libs/lwout_svg.o
.libs/lwout_x3d.o .libs/lwgeom_geos.o .libs/lwgeom_geos_clean.o
.libs/lwgeom_geos_node.o .libs/lwgeom_geos_split.o .libs/lwgeom_transform.o
.libs/lwspheroid.o   -L/usr/lib64 -lgeos_c -lproj    -Wl,-soname -Wl,
liblwgeom-2.0.0SVN.so -o .libs/liblwgeom-2.0.0SVN.so
libtool: link: (cd ".libs" && rm -f "liblwgeom.so" && ln -s "
liblwgeom-2.0.0SVN.so" "liblwgeom.so")
libtool: link: ar cru .libs/liblwgeom.a  stringbuffer.o measures.o
measures3d.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o
lwpoly.o lwtriangle.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o
lwpsurface.o lwtin.o lwout_wkb.o lwin_wkb.o lwout_wkt.o lwin_wkt_parse.o
lwin_wkt_lex.o lwin_wkt.o lwutil.o lwhomogenize.o lwalgorithm.o
lwsegmentize.o lwprint.o vsprintf.o g_box.o g_serialized.o g_util.o
lwgeodetic.o lwtree.o libtgeom.o lwout_gml.o lwout_kml.o lwout_geojson.o
lwout_svg.o lwout_x3d.o lwgeom_geos.o lwgeom_geos_clean.o
lwgeom_geos_node.o lwgeom_geos_split.o lwgeom_transform.o lwspheroid.o
libtool: link: ranlib .libs/liblwgeom.a
libtool: link: ( cd ".libs" && rm -f "liblwgeom.la" && ln -s "../
liblwgeom.la" "liblwgeom.la" )
make[1]: Leaving directory `/home/nathan/code/postgis/liblwgeom'
---- Making all in libpgcommon
make[1]: Entering directory `/home/nathan/code/postgis/libpgcommon'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/nathan/code/postgis/libpgcommon'
---- Making all in regress
make[1]: Entering directory `/home/nathan/code/postgis/regress'
make[1]: Leaving directory `/home/nathan/code/postgis/regress'
---- Making all in postgis
make[1]: Entering directory `/home/nathan/code/postgis/postgis'
gcc -E -traditional-cpp -I../libpgcommon postgis.sql.in.c | grep -v '^#' >
postgis.sql.in
sed 's,MODULE_PATHNAME,$libdir/postgis-2.0,g' postgis.sql.in >postgis.sql
gcc -E -traditional-cpp -I../libpgcommon uninstall_postgis.sql.in.c | grep
-v '^#' > uninstall_postgis.sql.in
uninstall_postgis.sql.in>uninstall_postgis.sql
cat postgis_drop_before.sql.in.c postgis.sql >
postgis_upgrade_20_minor.sql.in
'/usr/bin/perl' ../utils/postgis_proc_upgrade.pl
postgis_upgrade_20_minor.sql.in 2.0 > postgis_upgrade_20_minor.sql
gcc -E -traditional-cpp -I../libpgcommon legacy.sql.in.c | grep -v '^#' >
legacy.sql.in
sed 's,MODULE_PATHNAME,$libdir/postgis-2.0,g' legacy.sql.in >legacy.sql
gcc -E -traditional-cpp -I../libpgcommon uninstall_legacy.sql.in.c | grep
-v '^#' > uninstall_legacy.sql.in
uninstall_legacy.sql.in>uninstall_legacy.sql
legacy_compatibility_layer.sql.in.c | grep -v '^#' >
legacy_compatibility_layer.sql.in >legacy_compatibility_layer.sql
gcc -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
-I/usr/include/et -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Wendif-labels -Wformat-security
-fno-strict-aliasing -fwrapv -fpic -I/usr/include   -I/usr/include/libxml2
-I../liblwgeom -I../libpgcommon -I. -I. -I/usr/pgsql-9.1/include/server
-I/usr/pgsql-9.1/include/internal -I/usr/include/et -D_GNU_SOURCE
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_debug.o lwgeom_debug.c
-I/usr/include/libxml2  -I/usr/include  -c -o postgis_module.o
postgis_module.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_accum.o lwgeom_accum.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_spheroid.o
lwgeom_spheroid.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_ogc.o lwgeom_ogc.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_functions_analytic.o
lwgeom_functions_analytic.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_inout.o lwgeom_inout.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_functions_basic.o
lwgeom_functions_basic.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_btree.o lwgeom_btree.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_box.o lwgeom_box.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_box3d.o lwgeom_box3d.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_geos.o lwgeom_geos.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_geos_prepared.o
lwgeom_geos_prepared.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_geos_clean.o
lwgeom_geos_clean.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_geos_relatematch.o
lwgeom_geos_relatematch.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_export.o
lwgeom_export.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_in_gml.o
lwgeom_in_gml.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_in_kml.o
lwgeom_in_kml.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_in_geojson.o
lwgeom_in_geojson.c
lwgeom_in_geojson.c:19: warning: ‘geojson_lwerror’ defined but not used
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_triggers.o
lwgeom_triggers.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_dump.o lwgeom_dump.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_functions_lrs.o
lwgeom_functions_lrs.c
-I/usr/include/libxml2  -I/usr/include  -c -o long_xact.o long_xact.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_sqlmm.o lwgeom_sqlmm.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_rtree.o lwgeom_rtree.c
-I/usr/include/libxml2  -I/usr/include  -c -o lwgeom_transform.o
lwgeom_transform.c
-I/usr/include/libxml2  -I/usr/include  -c -o gserialized_typmod.o
gserialized_typmod.c
-I/usr/include/libxml2  -I/usr/include  -c -o gserialized_gist_2d.o
gserialized_gist_2d.c
-I/usr/include/libxml2  -I/usr/include  -c -o gserialized_gist_nd.o
gserialized_gist_nd.c
-I/usr/include/libxml2  -I/usr/include  -c -o geography_inout.o
geography_inout.c
-I/usr/include/libxml2  -I/usr/include  -c -o geography_btree.o
geography_btree.c
-I/usr/include/libxml2  -I/usr/include  -c -o geography_estimate.o
geography_estimate.c
-I/usr/include/libxml2  -I/usr/include  -c -o geography_measurement.o
geography_measurement.c
-I/usr/include/libxml2  -I/usr/include  -c -o geometry_estimate.o
geometry_estimate.c
-fno-strict-aliasing -fwrapv -fpic -shared -o postgis-2.0.so lwgeom_debug.o
postgis_module.o lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o
lwgeom_functions_analytic.o lwgeom_inout.o lwgeom_functions_basic.o
lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o lwgeom_geos.o
lwgeom_geos_prepared.o lwgeom_geos_clean.o lwgeom_geos_relatematch.o
lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geojson.o
lwgeom_triggers.o lwgeom_dump.o lwgeom_functions_lrs.o long_xact.o
lwgeom_sqlmm.o lwgeom_rtree.o lwgeom_transform.o gserialized_typmod.o
gserialized_gist_2d.o gserialized_gist_nd.o geography_inout.o
geography_btree.o geography_estimate.o geography_measurement.o
geometry_estimate.o  -L/usr/pgsql-9.1/lib -L/usr/lib64 -Wl,--as-needed
../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a  -L/usr/lib64
-lgeos_c -lproj  -lxml2 -lz -lm
make[1]: Leaving directory `/home/nathan/code/postgis/postgis'
---- Making all in loader
make[1]: Entering directory `/home/nathan/code/postgis/loader'
/bin/sh ../libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall
-Wmissing-prototypes  -DUSE_NLS
-DLOCALEDIR=\"/usr/pgsql-9.1/share/locale\"   shpopen.o dbfopen.o getopt.o
shp2pgsql-core.o shpcommon.o shp2pgsql-cli.o safileio.o ../liblwgeom/
liblwgeom.la -o shp2pgsql  -lc
libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -DUSE_NLS
shp2pgsql-core.o shpcommon.o shp2pgsql-cli.o safileio.o -o .libs/shp2pgsql
../liblwgeom/.libs/liblwgeom.so -L/usr/lib64 -lgeos_c -lproj -lc -Wl,-rpath
-Wl,/usr/local/lib
../liblwgeom/.libs/liblwgeom.so: undefined reference to `wkt_yylex'
../liblwgeom/.libs/liblwgeom.so: undefined reference to `wkt_lexer_init'
../liblwgeom/.libs/liblwgeom.so: undefined reference to `wkt_lexer_close'
collect2: ld returned 1 exit status
make[1]: *** [shp2pgsql] Error 1
make[1]: Leaving directory `/home/nathan/code/postgis/loader'
make: *** [all] Error 1
Thanks,
Nathaniel H Clay
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20111222/0cdd41d0/attachment.html>
