[postgis-devel] [PostGIS] #1404: [raster] raster2pgsql overviews don't look right
trac at osgeo.org
Sat Dec 24 10:58:28 PST 2011
Reporter: robe | Owner: pracine
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Okay its not that either. Bborie -- sorry I have no idea why it's working
now but doesn't seem to matter which slash I use. The same alignment
thing you fixed wouldn't have had anything to do with it would it. I
thought I might be using an older executable before.
I thought maybe it was the extra space but that didn't cause it to fail
either.
I'll close this out for now until I can replicate the issue again. I'm
going to test with the other server I have that has the released windows
install and see if I still see the same issue and then replace with trunk
and see if it still exhibits the issue
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1404#comment:11>
