[postgis-devel] [PostGIS] #1404: [raster] raster2pgsql overviews don't look right
PostGIS trac at osgeo.org
Sat Dec 24 11:06:27 PST 2011
  Reporter:  robe            |       Owner:  pracine
      Type:  defect          |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Comment(by dustymugs):
 The alignment issue had nothing to do with the loader.  I noticed that the
 alignment constraint was not being applied though it should have
 absolutely worked.
 Instead of using the wildcard (*) when passing in the rasters to the
 loader, could you explicitly provide the files?  Tedious yes, but I wonder
 if the shell's expansion of the wildcard is having issues.  The loader
 itself does no wildcard expansion.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1404#comment:12>
