[postgis-devel] [PostGIS] #827: Hudson has fallen again and can't get up
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Feb 14 01:52:08 PST 2011
>    Reporter:  robe        |       Owner:  chodgson
>        Type:  defect      |      Status:  closed
>    Priority:  medium      |   Milestone:  PostGIS 2.0.0
>   Component:  management  |     Version:  trunk
> Resolution:  fixed       |    Keywords:
> Changes (by robe):
>    * status:  new =>  closed
>    * resolution:  =>  fixed
> Comment:
>   Chris,
>   Thanks.  Looks like it is all set.  So I guess the lesson learned is can't
>   have sect2 in chapters that have ref sections.  I think that might have
>   been how I broke it last time too when I was playing around with sect2s in
>   Topology.
As a matter of interest, does it build locally for you when you make
these changes? If it does, then it sounds like a bug in the particular
versions of the tools on the build box.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
