[postgis-devel] [PostGIS] #827: Hudson has fallen againand can't get up
Paragon Corporation
lr at pcorp.us
Mon Feb 14 03:11:20 PST 2011
Correction refentry to sect2
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paragon
Corporation
Sent: Monday, February 14, 2011 6:10 AM
To: 'PostGIS Development Discussion'
Subject: Re: [postgis-devel] [PostGIS] #827: Hudson has fallen againand
can't get up
Mark,
I don't have the PDFLatex part or docbook setup. So whenever I make changes
I at most just make sure the xml passes my validation checks and that I can
build the comments files okay.
It actually passes thru everything (the building of the html etc) except the
PDFLatex part it gets hung. So maybe someone who can build on PDFLatex can
check by changing a refentry tag to a sect1 tag.
In thinking about it, I think it breaks when I try to mix refentry and sect2
tags in the same chapter because for refentries there is usually a page
break and for sect2 there isn't (well in the html). In the PDF -- they look
about the same to me, but I'm guessing it's the logic we have to do that
that makes the combination lethal. Its never a problem in other chapters.
Thanks,
Regina
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Monday, February 14, 2011 4:52 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] [PostGIS] #827: Hudson has fallen again and
can't get up
On 11/02/11 23:28, PostGIS wrote:
> #827: Hudson has fallen again and can't get up
> Reporter: robe | Owner: chodgson
> Type: defect | Status: closed
> Priority: medium | Milestone: PostGIS 2.0.0
> Component: management | Version: trunk
> Resolution: fixed | Keywords:
> Changes (by robe):
> * status: new => closed
> * resolution: => fixed
> Comment:
> Chris,
> Thanks. Looks like it is all set. So I guess the lesson learned is
can't
> have sect2 in chapters that have ref sections. I think that might have
> been how I broke it last time too when I was playing around with
> sect2s
in
> Topology.
As a matter of interest, does it build locally for you when you make these
changes? If it does, then it sounds like a bug in the particular versions of
the tools on the build box.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
