[postgis-devel] [PostGIS] #762: [raster] Raster some check fails
PostGIS trac at osgeo.org
Fri Feb 18 17:12:26 PST 2011
 Reporter:  aperi2007       |       Owner:  pracine
     Type:  defect          |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Old description:
> Hi,
> just executing "make raster-post-install-check" I see these errors:
> ./run_test check_raster_columns.sql check_raster_overviews.sql  rt_io.sql
> create_rt_bytea_test.sql rt_bytea.sql create_rt_box2d_test.sql
> rt_box2d.sql rt_addband.sql  create_rt_properties_test.sql
> rt_dimensions.sql rt_scale.sql rt_upperleft.sql rt_rotation.sql
> rt_georeference.sql rt_set_properties.sql create_rt_empty_raster_test.sql
> rt_isempty.sql rt_hasnoband.sql  create_rt_band_properties_test.sql
> rt_band_properties.sql rt_set_band_properties.sql  rt_pixelvalue.sql
> create_rt_utility_test.sql rt_utility.sql  create_rt_gist_test.sql
> rt_above.sql rt_below.sql rt_contained.sql rt_contain.sql rt_left.sql
> rt_overabove.sql rt_overbelow.sql rt_overlap.sql rt_overleft.sql
> rt_overright.sql rt_right.sql rt_same.sql  rt_spatial_relationship.sql
> bug_test_car5.sql
> Creating spatial db rtpostgis_reg
> createlang: linguaggio "plpgsql" già installato nel database
> "rtpostgis_reg"
> TMPDIR is /tmp/rtpgis_reg_11269
>  PostgreSQL 9.0.2 on i686-pc-linux-gnu, compiled by GCC gcc (Debian
> 4.3.2-1.1) 4.3.2, 32-bit
>  Postgis 2.0.0SVN - 2011-01-10 18:26:09
>    GEOS: 3.3.0-CAPI-1.7.0
>    PROJ: Rel. 4.7.1, 23 September 2009
>  WKTRaster 2.0.0SVN - 2011-01-10 18:26:09
> Running tests
>  check_raster_columns. ok
>  check_raster_overviews. ok
>  rt_io. ok
>  create_rt_bytea_test. ok
>  rt_bytea. ok
>  create_rt_box2d_test. ok
>  rt_box2d. ok
>  rt_addband. failed (diff expected obtained:
> /tmp/rtpgis_reg_11269/test_8_diff)
>  create_rt_properties_test. ok
>  rt_dimensions. ok
>  rt_scale. ok
>  rt_upperleft. ok
>  rt_rotation. ok
>  rt_georeference. ok
>  rt_set_properties. ok
>  create_rt_empty_raster_test. ok
>  rt_isempty. ok
>  rt_hasnoband. ok
>  create_rt_band_properties_test. ok
>  rt_band_properties. failed (diff expected obtained:
> /tmp/rtpgis_reg_11269/test_20_diff)
>  rt_set_band_properties. ok
>  rt_pixelvalue. ok
>  create_rt_utility_test. ok
>  rt_utility. ok
>  create_rt_gist_test. failed (diff expected obtained:
> /tmp/rtpgis_reg_11269/test_25_diff)
>  rt_above. ok
>  rt_below. ok
>  rt_contained. ok
>  rt_contain. ok
>  rt_left. ok
>  rt_overabove. ok
>  rt_overbelow. ok
>  rt_overlap. ok
>  rt_overleft. ok
>  rt_overright. ok
>  rt_right. ok
>  rt_same. ok
>  rt_spatial_relationship. ok
>  bug_test_car5. ok
> Run tests: 39
> Failed: 3
> make[3]: Leaving directory
> `/home/postgres/software/postgis/postgis-2.0.0SVN/raster/test/regress'
> make[2]: Leaving directory
> `/home/postgres/software/postgis/postgis-2.0.0SVN/raster/test'
> make[1]: Leaving directory
> `/home/postgres/software/postgis/postgis-2.0.0SVN/raster'
> postgres at deb:~/software/postgis/postgis-2.0.0SVN$
> I add the tmp logs.
New description:
 ./run_test ...
 "rtpostgis_reg"
 Running tests
  rt_io. ok
  rt_bytea. ok
  rt_box2d. ok
  rt_dimensions. ok
  rt_scale. ok
  rt_upperleft. ok
  rt_rotation. ok
  rt_georeference. ok
  rt_isempty. ok
  rt_hasnoband. ok
  rt_pixelvalue. ok
  rt_utility. ok
  rt_above. ok
  rt_below. ok
  rt_contained. ok
  rt_contain. ok
  rt_left. ok
  rt_overabove. ok
  rt_overbelow. ok
  rt_overlap. ok
  rt_overleft. ok
  rt_overright. ok
  rt_right. ok
  rt_same. ok
  bug_test_car5. ok
 Run tests: 39
 Failed: 3
 I add the tmp logs.
Comment(by mloskot):
 Description format
Ticket URL: <http://trac.osgeo.org/postgis/ticket/762#comment:5>
