[postgis-devel] [PostGIS] #762: [raster] Raster some check fails
trac at osgeo.org
Fri Feb 18 17:26:07 PST 2011
Reporter: aperi2007 | Owner: pracine
Type: defect | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by mloskot):
Some of the failures like ''rt_addband'' is related to the problem #792
I tried to run the raster-post-install-check for r6848 and getting even
more failures:
PostgreSQL 8.4.7 on x86_64-pc-linux-gnu, compiled by GCC gcc-4.4.real
(Ubuntu/Linaro 4.4.4-14ubuntu5) 4.4.5, 64-bit
Postgis 2.0.0SVN - 2011-02-19 01:10:53
GEOS: 3.3.0-CAPI-1.7.0
PROJ: Rel. 4.7.1, 23 September 2009
WKTRaster 2.0.0SVN - 2011-02-19 01:10:53
Running tests
check_raster_columns. ok
check_raster_overviews. ok
rt_io. ok
create_rt_bytea_test. ok
rt_bytea. ok
create_rt_box2d_test. ok
rt_box2d. ok
rt_addband. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_8_diff)
create_rt_properties_test. ok
rt_dimensions. ok
rt_scale. ok
rt_upperleft. ok
rt_rotation. ok
rt_georeference. ok
rt_set_properties. ok
create_rt_empty_raster_test. ok
rt_isempty. ok
rt_hasnoband. ok
create_rt_band_properties_test. ok
rt_band_properties. ok
rt_set_band_properties. ok
rt_pixelvalue. ok
create_rt_utility_test. ok
rt_utility. ok
create_rt_mapalgebra_test. ok
rt_mapalgebra. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_26_diff)
create_rt_gist_test. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_27_diff)
rt_above. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_28_diff)
rt_below. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_29_diff)
rt_contained. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_30_diff)
rt_contain. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_31_diff)
rt_left. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_32_diff)
rt_overabove. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_33_diff)
rt_overbelow. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_34_diff)
rt_overlap. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_35_diff)
rt_overleft. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_36_diff)
rt_overright. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_37_diff)
rt_right. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_38_diff)
rt_same. failed (diff expected obtained:
/tmp/rtpgis_reg_20787/test_39_diff)
rt_spatial_relationship. ok
bug_test_car5. ok
Run tests: 41
Failed: 15
AFAIU, most of them seem to be related to SQL functions renaming.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/762#comment:6>
