[postgis-devel] [PostGIS] #845: ST_Intersects() precision error - returns false instead of true
PostGIS trac at osgeo.org
Thu Feb 24 07:37:12 PST 2011
 Reporter:  cdestigter  |       Owner:  strk
     Type:  defect      |      Status:  assigned
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  postgis     |     Version:  1.5.X
 Keywords:  history     |
Comment(by nicklas):
 Well, I don't know if it really is unused. It just has no links in
 dOxygen. I don't know if that means it is totally unused.
 I think you can blindly do the same thing there. It really seems to have
 the same problem.
 Can it be that this function is called when creating the spatial index. I
 mean pointed at from sql and referenced by postgresql?
 Then it wouldn't show in doxygen.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/845#comment:37>
