[postgis-devel] [PostGIS] #788: Topology: ST_NewEdgesSplit don't work with more edges connected
PostGIS trac at osgeo.org
Wed Jan 19 02:47:36 PST 2011
  Reporter:  aperi2007  |       Owner:  strk
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.0.0
 Component:  topology   |     Version:  trunk
Resolution:  invalid    |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 The second parameter you pass to ST_NewEdgesSplit is the edge identifier.
 By using '1' you're asking it to split edge number 1, which in your case
 is likely
 the one NOT containing POINT(3 5).
 Try using '2', or even better, whatever AddEdge returned
Ticket URL: <http://trac.osgeo.org/postgis/ticket/788#comment:3>
