[postgis-devel] [PostGIS] #788: Topology: ST_NewEdgesSplit don't work with more edges connected
PostGIS trac at osgeo.org
Wed Jan 19 03:12:48 PST 2011
  Reporter:  aperi2007  |       Owner:  strk
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.0.0
 Component:  topology   |     Version:  trunk
Resolution:  invalid    |    Keywords:
Comment(by robe):
 Strk,
 doesn't ST_NewEdgesSplit always delete the original edge and create 2 new
 ones.  (We would use ST_ModEdgeSplit (for the other behavior).
 In which case shouldn't passing edge number 1 in again return a non-
 existent edge error.
 That was my understanding scanning the code you have and also
 corroborating with the SQL-MM doc I mentioned earlier.  Or do we just have
 a dangling record somewhere.
 Can you verify I documented this right?
 http://www.postgis.org/documentation/manual-svn/ST_NewEdgesSplit.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/788#comment:4>
