[postgis-devel] [PostGIS] #606: [raster] ST_Value should return NULL for nodata values
trac at osgeo.org
Wed Jan 19 13:44:21 PST 2011
Reporter: pracine | Owner: pracine
Type: enhancement | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
There should be a boolean option to disable this behavior and return the
true value of a nodata value pixel if required.
ST_Value(rast, x, y, FALSE)
In this case FALSE means "ignore the nodata value flag" or "do not take
nodata value into account and treat any nodata value like withdata
values".
By default the boolean option is TRUE and the function returns NULL (if
the value is nodata).
This boolean option have the same meaning as the one in st_intersects and
should be generalize to every fucntion when we want it to ignore nodata
values.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/606#comment:3>
