[postgis-devel] [PostGIS] #606: [raster] ST_Value should return NULL for nodata values
PostGIS trac at osgeo.org
Thu Jan 20 15:31:11 PST 2011
  Reporter:  pracine         |       Owner:  pracine
      Type:  enhancement     |      Status:  closed
  Priority:  critical        |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Changes (by pracine):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 -Fix at r6680
 ST_Value now return NULL for nodata value and ST_SetValue accept NULL
 values (if there is a nodata value in the band).
 ST_Value accept a boolean parameter which, when set to false, have the
 function to return nodata values as their true value instead of null.
 Some plpgsql scripts will have to be updated.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/606#comment:4>
