[postgis-devel] [PostGIS] #1064: [raster] transform regress failing on 8.4 windows build
trac at osgeo.org
Fri Jul 1 21:48:56 PDT 2011
Reporter: robe | Owner: dustymugs
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
Old description:
> I'm not sure if its just something changed in my setup or not, but the
> rt_transform tests are failing on my 8.4 windows builds. What's odd is
> that they are passing on my 9.0 and 9.1beta2 windows builds.
> I though it was maybe because I rebuilt gdal and perhaps my settings were
> off, but such things usually make all 3 fail.
> Anyrate attached is the regress failure.
New description:
Comment:
Bborie,
I apologize for the waste of time. I figured out what is different about
my 8.4.
I had an extra line in my Pg 8.4 database launch script that had:
@SET GDAL_DATA=C:\projects\gdal\rel-trunk\share\gdal
That folder has a bunch of transform csv files. It was alsoo at a time
when I rebuilt GDAL so could also be a permission issue with that folder.
and it was giving errors like the below in the log when transform was done
ERROR 6: Unable to load PROJ.4 library ("libproj.dll"), creation of
OGRCoordinateTransformation failed.
Not sure why that line even matters unless they are proj 4.7 specific
files and somehow force proj to override its standard behavior.
Anyrate we didn't have it in our 9.0 and 9.1 pg launch scripts. Once I
got rid of that line all worked fine. I'm not sure though what happens if
people have that in their global environment variables. They might run
into the same issues I suppose as I think PostgreSQL pays attention to
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1064#comment:11>
