[postgis-devel] [PostGIS] #1064: [raster] transform regress failing on 8.4 windows build
PostGIS trac at osgeo.org
Sat Jul 2 13:40:17 PDT 2011
  Reporter:  robe            |       Owner:  dustymugs
      Type:  defect          |      Status:  closed
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Comment(by dustymugs):
 I have mixed feelings about how this ticket resolved.  I'm concerned as
 you are that other users will have similar configurations thus causing the
 same problem.  Also, I don't ever like not understanding was the problem
 is.  I'm glad that you've found out what was causing the regression
 failure as that allows me to start figuring out tickets #1061 and #1066,
 which I have a hunch is the same issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1064#comment:12>
