[postgis-devel] RFC: Remove mmin and mmax from GBOX
Paul Ramsey pramsey at opengeo.org
Wed Jul 6 09:38:28 PDT 2011
Yeah, by removing the fourth dimension you're foreclosing on 4d
indexing to some extent, since gboxes are used to pass around full
extents of 4d objects.
On Wed, Jul 6, 2011 at 7:41 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Hi all,
> Whilst trying to get rid of the following compile warning:
> gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith
> -Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing -fwrapv
> -fpic -I/home/pg90/rel/include  -I/usr/include/libxml2 -I../liblwgeom -I.
> -I. -I/home/pg90/rel/include/postgresql/server
> -I/home/pg90/rel/include/postgresql/internal -D_GNU_SOURCE   -c -o
> geography_estimate.o geography_estimate.c
> geography_estimate.c: In function ‘compute_geography_stats’:
> geography_estimate.c:1048: warning: ‘histobox.mmax’ may be used
> uninitialized in this function
> geography_estimate.c:1048: warning: ‘histobox.mmin’ may be used
> geography_estimate.c:1048: warning: ‘histobox.flags’ may be used
> it suddenly struck me that we are doing some strange and inconsistent things
> with the M value when building GBOXes. Looking closer at the logic, I've so
> far come to the conclusion that M is an attribute, not an extra dimension
> and so on this basis it has no spatial component and therefore should not be
> stored within GBOX.
> Therefore I'd like to propose the attached patch to remove M from GBOX
> entirely - thoughts?
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
