[postgis-devel] RFC: Remove mmin and mmax from GBOX
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Jul 6 09:47:32 PDT 2011
On 06/07/11 17:38, Paul Ramsey wrote:
> Yeah, by removing the fourth dimension you're foreclosing on 4d
> indexing to some extent, since gboxes are used to pass around full
> extents of 4d objects.
But that's the misunderstanding here - M isn't a dimension. It's an
arbitrary numerical attribute attached to the geometry.
Thinking about this some more, I was wondering if we could change
GSERIALIZED a bit. Currently we have this:
typedef struct
uint32 size; /* For PgSQL use, use VAR* macros to manipulate. */
uchar srid[3]; /* 21 bits of SRID (and 3 spare bits) */
uchar flags; /* HasZ, HasM, HasBBox, IsGeodetic */
uchar data[1]; /* See gserialized.txt */
} GSERIALIZED;
I'm thinking that instead of HasZ we should simply reserve 2 bits for
the number of dimensions, and then if a measure is present the HasM bit
can be set. This will give us up to 4 dimensions for people to play
with, and will also tidy up the HasZ/HasM handling. Do people think 4
dimensions is currently enough? I'm happy to go ahead and do the work to
make the relevant changes.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
