[postgis-devel] [PostGIS] #1015: [raster] segfault on make check
PostGIS trac at osgeo.org
Fri Jun 10 09:37:44 PDT 2011
 Reporter:  strk            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 as of r7341, on a 64bit with gdal 1.9.0:
 WARNING: Value set for 32BF band got converted from 98.989848 to 98.989845
 WARNING: Value set for 32BF band got converted from 99.494949 to 99.494949
 WARNING: Value set for 32BF band got converted from 99.994975 to 99.994972
 ERROR 5: GDALWarpOptions.Validate()
   padfSrcNoDataReal set, but padfSrcNoDataImag not set.
 make[3]: *** [check] Segmentation fault
 make[3]: Leaving directory `/home/src/postgis/postgis/raster/test/core'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1015>
