[postgis-devel] [PostGIS] #1015: [raster] segfault on make check
trac at osgeo.org
Fri Jun 10 09:47:20 PDT 2011
Reporter: strk | Owner: pracine
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
This look like it's failing on the transform too -- ah we have a Linux
victim suffering the same pains as a windows person :).
I'll double check on my end - but I think this is a dupe #925.
On windows under mingw, I believe I get the same error followed by can't
load libproj-0.dll.
Strk -- to confirm -- can you look at that ticket and try the regress for
transform on your linux box and confirm you are getting the wrong answers?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1015#comment:1>
