[postgis-devel] [PostGIS] #609: Bad source code in manual section 5.2 Java Clients
trac at osgeo.org
Fri Jun 10 10:25:29 PDT 2011
Reporter: simoc | Owner: pramsey
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Resolution: fixed | Keywords: JDBC client documentation
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Okay I feel the recommendation for first part is wrong. Last bit of java
programming I tortured myself with -- I think I used this syntax --
http://jdbc.postgresql.org/documentation/publicapi/org/postgresql/PGConnection.html
and a JDBC4 driver.
So I have instead opted to replace the first part with
((org.postgresql.PGConnection)conn).addDataType("geometry","org.postgis.PGgeometry");
((org.postgresql.PGConnection)conn).addDataType("box3d","org.postgis.PGbox3d");
the rest of the suggestions look fine, but I haven't tested the code and
am not really setup to at the moment.
so fixed at r7362 for PostGIS 1.5 and r7363 for PostGIS 2.0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/609#comment:2>
