[postgis-devel] [PostGIS] #609: Bad source code in manual section 5.2 Java Clients
PostGIS trac at osgeo.org
Mon Jun 13 04:07:41 PDT 2011
  Reporter:  simoc    |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  low      |   Milestone:  PostGIS 1.5.3
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:  JDBC client documentation
Comment(by simoc):
 Yes, using PGConnection.addDataType(String, String) also works for me,
 although that method is deprecated.  The recommended replacement method in
 the PGConnection Javadoc is:
 ((org.postgresql.PGConnection)conn).addDataType("geometry",Class.forName("org.postgis.PGgeometry"));
 ((org.postgresql.PGConnection)conn).addDataType("box3d",Class.forName("org.postgis.PGbox3d"));
 That method also works correctly for me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/609#comment:3>
