[postgis-devel] [PostGIS] #925: [raster] ST_Transform
trac at osgeo.org
Fri Jun 10 11:47:44 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: history |
Comment(by pracine):
Tested r7365. Same problem:
ERROR 6: Unable to load PROJ.4 library (libproj-0.dll), creation of
OGRCoordinateTransformation failed.
GDALDataset
Check failed on line 1490
make[2]: *** [check] Error 1
make[2]: Leaving directory `/c/thesrc/postgis/postgis-
trunk/raster/test/core'
make[1]: *** [core-check] Error 2
make[1]: Leaving directory `/c/thesrc/postgis/postgis-trunk/raster/test'
make: *** [core-check] Error 2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:42>
