[postgis-devel] [PostGIS] #925: [raster] ST_Transform
trac at osgeo.org
Fri Jun 10 11:55:18 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: history |
Comment(by dustymugs):
Interesting. That detailed error message tells me that the problem I
fixed is something different. strk, can you try again with r7364 or
later?
Pierre, what I can tell you based on the "creation of
OGRCoordinateTransformation failed" part is that you'll need to set the
environment variable PROJSO. See:
http://trac.osgeo.org/gdal/wiki/ConfigOptions#PROJSO
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:43>
