[postgis-devel] [PostGIS] #925: [raster] ST_Transform
trac at osgeo.org
Fri Jun 10 15:03:30 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: history |
Comment(by robe):
Bborie,
It works under PostgreSQL now. I thought I had my global environment
PROJSO set, but I had a typo. So fixing that worked. Though I could have
sworn the first time they all registered as NULL -- all the fields. But
can't recreate that again. So I guess you don't need to venture into
windows land.
strk -- can you confirm things work for you with PROJSO environment
variable
then I guess we can close this out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:50>
