[postgis-devel] [PostGIS] #925: [raster] ST_Transform
trac at osgeo.org
Fri Jun 10 15:06:11 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: history |
Comment(by dustymugs):
Pierre,
It's quite strange as to what is happening in the regression. When I test
on 1.7.3, the same two tests fail but with different values. Both tests
are for different resampling algorithms (Bilinear and Cubic).
Regina,
What version of GDAL are you using?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:51>
