[postgis-devel] [PostGIS] #1021: Most topology regress failing after GSERIALIZED enabled: gist_geometry_ops does not exist for access method gist (was: Most raster regress failing after GSERIALIZED enabled: gist_geometry_ops does not exist for access method gist)
PostGIS trac at osgeo.org
Tue Jun 14 00:38:30 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1021#comment:1>
