[postgis-devel] [PostGIS] #1021: Most topology regress failing after GSERIALIZED enabled: gist_geometry_ops does not exist for access method gist
trac at osgeo.org
Tue Jun 14 18:40:57 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Comment(by robe):
strk -- after your fix at r7393 I no longer get this error, so feel free
to close if you are satisfied.
However we are not out of the woods yet. I still get regression failures
on topology, but down to 1-2 failures and differs on PostgreSQL version.
They might just be rounding differences. I'll put that in as a separate
ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1021#comment:2>
