[postgis-devel] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() to even/odd side of street
trac at osgeo.org
Wed Jun 22 13:30:43 PDT 2011
Reporter: mikepease | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
I've been comparing the results of the Tiger Geocoder to Google's
Geocoder. I sent in a list of about 70,000 addresses in Minnesota.
I'm getting about 89% successful results where Google's geocode and
Tiger's geocode produce similar results. Not bad.
One difference that I'd love to see in the Tiger Geocoder would be to
place an address point either on the even or odd side of the street. It
appears that the geocodes are all placed on the center line of the street.
Is that correct?
It would be super cool if you could determine which side of the street an
address is on and then shift the geocode to that side, say by 20 meters
(65 feet). Now, determining which angle to translate the point can be a
trick, for sure.
I did a similar operation in the past by grabbing a short line segment
from the street and rotating it 90 degrees in order to find the even/odd
side offsets from the center line. That code looked like this:
rotate_oncenter(
MakeLine(ST_Line_Interpolate_Point(ST_GeometryN(the_geom,1),
offset_percent1 ),
ST_Line_Interpolate_Point(ST_GeometryN(the_geom,1), offset_percent2 ))
, 90) as rotated_line
then you could use the end points of this rotated segment to get the
even/odd odd side of the street.
ST_Line_Interpolate_Point(rotated_line,0) --even side of street
ST_Line_Interpolate_Point(rotated_line,1) --odd side of street
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1052>
