[postgis-devel] [PostGIS] #1058: [raster] Two-raster spatial operations framework proposal
trac at osgeo.org
Thu Jun 23 16:14:05 PDT 2011
Reporter: bnordgren | Owner: pracine
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: 1.5.X
Keywords: |
Comment(by bnordgren):
Linking to the shared postgis library in the build directory is causing
problems at runtime (after install). I could use some help on this one:
psql:rtpostgis.sql:39: NOTICE: type "raster" is not yet defined
DETAIL: Creating a shell type definition.
psql:rtpostgis.sql:39: ERROR:
could not load library "/usr/lib/postgresql/rtpostgis-2.0.so":
/home/bnordgren/build/local/postgis-svn/src/trunk-
build/postgis/postgis-2.0.so:
cannot open shared object file: Permission denied
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1058#comment:2>
