[postgis-devel] [PostGIS] #1058: [raster] Two-raster spatial operations framework proposal
PostGIS trac at osgeo.org
Fri Jun 24 07:24:53 PDT 2011
 Reporter:  bnordgren       |       Owner:  pracine
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  1.5.X
 Keywords:                  |
Comment(by mcayland):
 I think that the way in which you're doing this is wrong and likely to
 cause strange runtime errors depending upon the linkers in different
 platforms.
 I would suggest that you submit as 2 separate patches: the first to
 abstract and move the PROJ.4 cache API into liblwgeom, and then a second
 implementing your new functionality.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1058#comment:3>
