[postgis-devel] Fwd: Build failed in Hudson: PostGIS-trunk-regression #568
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 28 07:14:04 PDT 2011
---------- Forwarded message ----------
Date: Mon, Mar 28, 2011 at 5:40 AM
Subject: Re: Build failed in Hudson: PostGIS-trunk-regression #568
To: Paul Ramsey <pramsey at cleverelephant.ca>
They are my tests, and while they "work on my machine" I think there's still
a cross-platform precision issue with them. I was hoping to test under
Windows (since Regina was the first one to complain about them not working)
but I haven't been able to get GEOS to build yet :(. That said I haven't
spent that much time on it so I'm hoping to get it up and running in the
next couple days.
Jeff
On Sun, Mar 27, 2011 at 6:23 PM, Paul Ramsey <pramsey at cleverelephant.ca>wrote:
> Jeff, could these be yours?
> P
> From: Nicklas Avén <nicklas.aven at jordogskog.no>
> Date: Sun, Mar 27, 2011 at 11:49 AM
> To: kneufeld at refractions.net
> Cc: strk at keybit.net, Pierre.Racine at sbf.ulaval.ca,
> pramsey at cleverelephant.ca, robe.dnd at cityofboston.gov,
> jorgearevalo at gis4free.org
> Hmm, I can't see how my commit can have affected this.
> In the two reprojection fails the differences is very small and they
> pass on my local machine.
> The ticket failure I guess must have been there before my commit since
> also that one has nothing to do with my commit. I have tried to read
> through the diff I comitted and can't see anything that shouldn't be
> there.
> http://trac.osgeo.org/postgis/changeset/6974
> When I lock in the link below at office.refractions ......
> as I understand it this failures has been there for a while. Is it so?
> Does it send this message even the failures has nothing to do with the
> changes that is pointed out in the mail?
> /Nicklas
> On Sun, 2011-03-27 at 11:08 -0700, kneufeld at refractions.net wrote:
> > See <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/568/changes
> > Changes:
> > [Nicklas Aven] Renaming of 3D functions, #817
> > [...truncated 2227 lines...]
> > Test: test_wkt_in_multipoint ... passed
> > Test: test_wkt_in_multilinestring ... passed
> > Test: test_wkt_in_multipolygon ... passed
> > Test: test_wkt_in_collection ... passed
> > Test: test_wkt_in_circularstring ... passed
> > Test: test_wkt_in_compoundcurve ... passed
> > Test: test_wkt_in_curvpolygon ... passed
> > Test: test_wkt_in_multicurve ... passed
> > Test: test_wkt_in_multisurface ... passed
> > Test: test_wkt_in_polyhedralsurface ... passed
> > Test: test_wkt_in_errlocation ... passed
> > Suite: WKB Out Suite
> > Test: test_wkb_out_point ... passed
> > Test: test_wkb_out_linestring ... passed
> > Test: test_wkb_out_polygon ... passed
> > Test: test_wkb_out_multipoint ... passed
> > Test: test_wkb_out_multilinestring ... passed
> > Test: test_wkb_out_multipolygon ... passed
> > Test: test_wkb_out_collection ... passed
> > Test: test_wkb_out_circularstring ... passed
> > Test: test_wkb_out_compoundcurve ... passed
> > Test: test_wkb_out_curvpolygon ... passed
> > Test: test_wkb_out_multicurve ... passed
> > Test: test_wkb_out_multisurface ... passed
> > Test: test_wkb_out_polyhedralsurface ... passed
> > Suite: WKB In Suite
> > Test: test_wkb_in_point ... passed
> > Test: test_wkb_in_linestring ... passed
> > Test: test_wkb_in_polygon ... passed
> > Test: test_wkb_in_multipoint ... passed
> > Test: test_wkb_in_multilinestring ... passed
> > Test: test_wkb_in_multipolygon ... passed
> > Test: test_wkb_in_collection ... passed
> > Test: test_wkb_in_circularstring ... passed
> > Test: test_wkb_in_compoundcurve ... passed
> > Test: test_wkb_in_curvpolygon ... passed
> > Test: test_wkb_in_multicurve ... passed
> > Test: test_wkb_in_multisurface ... passed
> > Suite: LibGeom Suite
> > Test: test_typmod_macros ... passed
> > Test: test_flags_macros ... passed
> > Test: test_serialized_srid ... passed
> > Test: test_gserialized_from_lwgeom_size ... passed
> > Test: test_gbox_serialized_size ... passed
> > Test: test_lwgeom_from_gserialized ... passed
> > Test: test_lwgeom_count_vertices ... passed
> > Test: test_on_gser_lwgeom_count_vertices ... passed
> > Test: test_geometry_type_from_string ... passed
> > Test: test_lwcollection_extract ... passed
> > Test: test_lwgeom_free ... passed
> > Test: test_lwgeom_flip_coordinates ... passed
> > Test: test_f2d ... passed
> > Suite: Triangle, Tin and PolyhedralSurface Suite
> > Test: triangle_parse ... passed
> > Test: tin_parse ... passed
> > Test: polyhedralsurface_parse ... passed
> > Test: tin_tgeom ... passed
> > Test: psurface_tgeom ... passed
> > Test: surface_dimension ... passed
> > Test: surface_perimeter ... passed
> > Suite: Geodetic Suite
> > Test: test_signum ... passed
> > Test: test_gbox_from_spherical_coordinates ... passed
> > Test: test_gserialized_get_gbox_geocentric ... passed
> > Test: test_clairaut ... passed
> > Test: test_edge_intersection ... passed
> > Test: test_edge_distance_to_point ... passed
> > Test: test_edge_distance_to_edge ... passed
> > Test: test_lwgeom_distance_sphere ... passed
> > Test: test_lwgeom_check_geodetic ... passed
> > Test: test_gbox_calculation ... passed
> > Test: test_gserialized_from_lwgeom ... passed
> > Test: test_spheroid_distance ... passed
> > Test: test_spheroid_area ... passed
> > Test: test_lwpoly_covers_point2d ... passed
> > Test: test_ptarray_point_in_ring ... passed
> > Suite: Homogenize Suite
> > Test: test_coll_point ... passed
> > Test: test_coll_line ... passed
> > Test: test_coll_poly ... passed
> > Test: test_coll_coll ... passed
> > Test: test_geom ... passed
> > Suite: GML Out Suite
> > Test: out_gml_test_precision ... passed
> > Test: out_gml_test_srid ... passed
> > Test: out_gml_test_dims ... passed
> > Test: out_gml_test_geodetic ... passed
> > Test: out_gml_test_geoms ... passed
> > Test: out_gml_test_geoms_prefix ... passed
> > Test: out_gml_test_geoms_nodims ... passed
> > Suite: KML Out Suite
> > Test: out_kml_test_precision ... passed
> > Test: out_kml_test_dims ... passed
> > Test: out_kml_test_geoms ... passed
> > Test: out_kml_test_prefix ... passed
> > Suite: GeoJson Out Suite
> > Test: out_geojson_test_precision ... passed
> > Test: out_geojson_test_dims ... passed
> > Test: out_geojson_test_srid ... passed
> > Test: out_geojson_test_bbox ... passed
> > Test: out_geojson_test_geoms ... passed
> > Suite: SVG Out Suite
> > Test: out_svg_test_precision ... passed
> > Test: out_svg_test_dims ... passed
> > Test: out_svg_test_relative ... passed
> > Test: out_svg_test_geoms ... passed
> > Test: out_svg_test_srid ... passed
> > --Run Summary: Type Total Ran Passed Failed
> > suites 17 17 n/a 0
> > tests 143 143 143 0
> > asserts 1229 1229 1229 0
> > make[2]: Leaving directory `<
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/liblwgeom/cunit
> > make[1]: Leaving directory `<
> > ---- Making check in regress
> > make[1]: Entering directory `<
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/regress
> > sed 's,$libdir,<
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/regress/00-regress-install/lib,g'>
> ../postgis/postgis.sql > postgis.sql
> > make -C ../postgis REGRESS=1 DESTDIR=<
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/regress/00-regress-install>
> install
> > make[2]: Entering directory `<
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/postgis
> > Makefile.pgxs:17: warning: overriding commands for target `install'
> > /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:96:
> warning: ignoring old commands for target `install'
> > Makefile.pgxs:63: warning: overriding commands for target `installdirs'
> > /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:143:
> warning: ignoring old commands for target `installdirs'
> > Makefile.pgxs:82: warning: overriding commands for target `uninstall'
> > /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:163:
> warning: ignoring old commands for target `uninstall'
> > mkdir -p -- <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/regress/00-regress-install/share/contrib/postgis-2.0
> > /bin/sh
> /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/../../config/install-sh
> -c -m 644 ./../spatial_ref_sys.sql '<
> > /bin/sh
> -c -m 644 postgis.sql '<
> > /bin/sh
> -c -m 644 uninstall_postgis.sql '<
> > /bin/sh
> -c -m 644 postgis_upgrade_15_minor.sql '<
> > /bin/sh
> -c -m 644 postgis_upgrade_14_to_15.sql '<
> > /bin/sh
> -c -m 644 postgis_upgrade_13_to_15.sql '<
> > /bin/sh
> -c -m 755 libpostgis-2.0.so.0.0 '<
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/regress/00-regress-install/lib/postgis-2.0.so
> > make -C ../loader REGRESS=1 DESTDIR=<
> install
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/loader
> > Makefile:136: warning: overriding commands for target `clean'
> > /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:209:
> warning: ignoring old commands for target `clean'
> > /bin/sh
> -c pgsql2shp <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/regress/00-regress-install/bin
> > /bin/sh
> -c shp2pgsql <
> > Creating spatial db postgis_reg
> > TMPDIR is <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/results_8.3.12_3.2.2_4.7.0
> > PATH is
> /var/home/buildbot/opt/pgsql/8.3.12/bin:/usr/local/bin:/bin:/usr/bin:/var/home/buildbot/opt/pgsql/8.3.12/bin
> > PostgreSQL 8.3.12 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 4.1.2
> 20080704 (Red Hat 4.1.2-48)
> > Postgis 2.0.0SVN - 2011-03-27 18:06:37
> > GEOS: 3.2.2-CAPI-1.6.2
> > PROJ: Rel. 4.7.1, 23 September 2009
> > Running tests
> > loader/Point........................... ok
> > loader/PointM............................ ok
> > loader/PointZ............................ ok
> > loader/MultiPoint............................ ok
> > loader/MultiPointM............................ ok
> > loader/MultiPointZ............................ ok
> > loader/Arc............................ ok
> > loader/ArcM............................ ok
> > loader/ArcZ............................ ok
> > loader/Polygon............................ ok
> > loader/PolygonM............................ ok
> > loader/PolygonZ............................ ok
> > loader/TSTPolygon.......... ok
> > loader/TSIPolygon.......... ok
> > loader/TSTIPolygon.......... ok
> > loader/PointWithSchema..... ok
> > loader/NoTransPoint......... ok
> > loader/NotReallyMultiPoint.................. ok
> > loader/MultiToSinglePoint.......... ok
> > loader/ReprojectPts..... failed (wkt test: diff expected obtained: <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/results_8.3.12_3.2.2_4.7.0/test_20_diff
> > loader/ReprojectPtsGeog..... failed (wkt test: diff expected obtained: <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/results_8.3.12_3.2.2_4.7.0/test_21_diff
> > loader/Latin1.... ok
> > regress. ok
> > regress_index. ok
> > regress_index_nulls. ok
> > lwgeom_regress. ok
> > regress_lrs. ok
> > removepoint. ok
> > setpoint. ok
> > simplify. ok
> > snaptogrid. ok
> > affine. ok
> > measures. ok
> > long_xact. ok
> > ctors. ok
> > sql-mm-serialize. ok
> > sql-mm-circularstring. ok
> > sql-mm-compoundcurve. ok
> > sql-mm-curvepoly. ok
> > sql-mm-general. ok
> > sql-mm-multicurve. ok
> > sql-mm-multisurface. ok
> > polyhedralsurface. ok
> > polygonize. ok
> > out_geometry. ok
> > out_geography. ok
> > in_gml. ok
> > in_kml. ok
> > iscollection. ok
> > regress_ogc. ok
> > regress_ogc_cover. ok
> > regress_ogc_prep. ok
> > regress_bdpoly. ok
> > regress_proj. ok
> > regress_management. ok
> > dump. ok
> > dumppoints. ok
> > wmsservers_new. ok
> > tickets. failed (diff expected obtained: <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/results_8.3.12_3.2.2_4.7.0/test_59_diff
> > remove_repeated_points. ok
> > split. ok
> > relate. ok
> > hausdorff. ok
> > regress_buffer_params. ok
> > Run tests: 64
> > Failed: 3
> > make[1]: *** [check] Error 3
> > make: *** [check] Error 1
> > + mv <
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/results_8.3.12_3.2.2_4.7.0/regress_log>
> http://office.refractions.net:1500/job/PostGIS-trunk-regression/568/artifact/results_8.3.12_3.2.2_4.7.0/install-TRUNK_6974_8.3.12_3.2.2_4.7.0.log
> > ++ psql -l
> > ++ grep postgis_reg
> > ++ wc -l
> > + '[' 0 -gt 0 ']'
> > + pgsql1 stop
> > ++ find -name 'results*'
> > + for d in '`find -name '\''results*'\''`'
> > + cd ./results_8.3.12_3.2.2_4.7.0
> > ++ grep ERROR ./dumper.dbf ./dumper.err ./dumper.shp ./dumper.shx
> ./install-TRUNK_6974_8.3.12_3.2.2_4.7.0.log ./loader ./loader.err
> ./regress-TRUNK_6974_8.3.12_3.2.2_4.7.0.log ./test_20_diff ./test_20_out
> ./test_21_diff ./test_21_out ./test_59_diff ./test_59_out
> > ++ wc -l
> > + '[' 12 -gt 0 ']'
> > ./dumper.err:WARNING: Could not execute prj query: ERROR: schema "pgreg"
> does not exist
> > ./test_59_out:ERROR: AddGeometryColumns() - invalid SRID
> > ./test_59_out:ERROR: lwgeom_to_gml2: 'CurvePolygon' geometry type not
> supported
> > ./test_59_out:ERROR: lwgeom_longitude_shift: unsupported geom type:
> CircularString
> > ./test_59_out:ERROR: Unsupported geometry type: CircularString
> > ./test_59_out:ERROR: Geometry argument does not have an 'M' ordinate
> > ./test_59_out:ERROR: lwgeom_grid: Unsupported geometry type:
> CircularString
> > ./test_59_out:ERROR: incontinuous compound curve
> > ./test_59_out:ERROR: Invalid hex string, length (267) has to be a
> multiple of two!
> > ./test_59_out:ERROR: Input geometries must be points
> > ./test_59_out:ERROR: Shell is not a line
> > ./test_59_out:ERROR: First argument must be a LINESTRING
> > + exit 1
> > Archiving artifacts
Jeff Adams
Azavea | 340 N 12th St, Ste 402, Philadelphia, PA
jadams at azavea.com | T 215.701.7717 | F 215.925.2663
Web azavea.com | Blog azavea.com/blogs | Twitter
@azavea<http://twitter.com/azavea>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110328/ade5ee4b/attachment.html>
