[postgis-devel] Fwd: Build failed in Hudson:PostGIS-trunk-regression #568
Paragon Corporation
lr at pcorp.us
Mon Mar 28 09:08:11 PDT 2011
Slight clarification
The loader reproject tests work fine on Windows. I think it was strk
complaining about that on his 64-bit machine and that's just a rounding
error which I'm not sure why we can't just use ST_SnapToGrid to fix.
What doesn't work on windows is the load schema test, but that is just
windows and we have a workaround for that which isn't pretty but works
The one we are really concerned about is and this one fails for everyone.
http://trac.osgeo.org/postgis/ticket/869
Thanks,
Regina
_____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Monday, March 28, 2011 10:14 AM
To: PostGIS Development Discussion
Subject: [postgis-devel] Fwd: Build failed in
---------- Forwarded message ----------
Date: Mon, Mar 28, 2011 at 5:40 AM
Subject: Re: Build failed in Hudson: PostGIS-trunk-regression #568
To: Paul Ramsey <pramsey at cleverelephant.ca>
They are my tests, and while they "work on my machine" I think there's still
a cross-platform precision issue with them. I was hoping to test under
Windows (since Regina was the first one to complain about them not working)
but I haven't been able to get GEOS to build yet :(. That said I haven't
spent that much time on it so I'm hoping to get it up and running in the
next couple days.
Jeff
On Sun, Mar 27, 2011 at 6:23 PM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
Jeff, could these be yours?
P
Date: Sun, Mar 27, 2011 at 11:49 AM
To: kneufeld at refractions.net
Cc: strk at keybit.net, Pierre.Racine at sbf.ulaval.ca, pramsey at cleverelephant.ca,
robe.dnd at cityofboston.gov, jorgearevalo at gis4free.org
Hmm, I can't see how my commit can have affected this.
In the two reprojection fails the differences is very small and they
pass on my local machine.
The ticket failure I guess must have been there before my commit since
also that one has nothing to do with my commit. I have tried to read
through the diff I comitted and can't see anything that shouldn't be
there.
http://trac.osgeo.org/postgis/changeset/6974
When I lock in the link below at office.refractions ......
as I understand it this failures has been there for a while. Is it so?
Does it send this message even the failures has nothing to do with the
changes that is pointed out in the mail?
/Nicklas
On Sun, 2011-03-27 at 11:08 -0700, kneufeld at refractions.net wrote:
> See
<http://office.refractions.net:1500/job/PostGIS-trunk-regression/568/changes
> Changes:
> [Nicklas Aven] Renaming of 3D functions, #817
> [...truncated 2227 lines...]
> Test: test_wkt_in_multipoint ... passed
> Test: test_wkt_in_multilinestring ... passed
> Test: test_wkt_in_multipolygon ... passed
> Test: test_wkt_in_collection ... passed
> Test: test_wkt_in_circularstring ... passed
> Test: test_wkt_in_compoundcurve ... passed
> Test: test_wkt_in_curvpolygon ... passed
> Test: test_wkt_in_multicurve ... passed
> Test: test_wkt_in_multisurface ... passed
> Test: test_wkt_in_polyhedralsurface ... passed
> Test: test_wkt_in_errlocation ... passed
> Suite: WKB Out Suite
> Test: test_wkb_out_point ... passed
> Test: test_wkb_out_linestring ... passed
> Test: test_wkb_out_polygon ... passed
> Test: test_wkb_out_multipoint ... passed
> Test: test_wkb_out_multilinestring ... passed
> Test: test_wkb_out_multipolygon ... passed
> Test: test_wkb_out_collection ... passed
> Test: test_wkb_out_circularstring ... passed
> Test: test_wkb_out_compoundcurve ... passed
> Test: test_wkb_out_curvpolygon ... passed
> Test: test_wkb_out_multicurve ... passed
> Test: test_wkb_out_multisurface ... passed
> Test: test_wkb_out_polyhedralsurface ... passed
> Suite: WKB In Suite
> Test: test_wkb_in_point ... passed
> Test: test_wkb_in_linestring ... passed
> Test: test_wkb_in_polygon ... passed
> Test: test_wkb_in_multipoint ... passed
> Test: test_wkb_in_multilinestring ... passed
> Test: test_wkb_in_multipolygon ... passed
> Test: test_wkb_in_collection ... passed
> Test: test_wkb_in_circularstring ... passed
> Test: test_wkb_in_compoundcurve ... passed
> Test: test_wkb_in_curvpolygon ... passed
> Test: test_wkb_in_multicurve ... passed
> Test: test_wkb_in_multisurface ... passed
> Suite: LibGeom Suite
> Test: test_typmod_macros ... passed
> Test: test_flags_macros ... passed
> Test: test_serialized_srid ... passed
> Test: test_gserialized_from_lwgeom_size ... passed
> Test: test_gbox_serialized_size ... passed
> Test: test_lwgeom_from_gserialized ... passed
> Test: test_lwgeom_count_vertices ... passed
> Test: test_on_gser_lwgeom_count_vertices ... passed
> Test: test_geometry_type_from_string ... passed
> Test: test_lwcollection_extract ... passed
> Test: test_lwgeom_free ... passed
> Test: test_lwgeom_flip_coordinates ... passed
> Test: test_f2d ... passed
> Suite: Triangle, Tin and PolyhedralSurface Suite
> Test: triangle_parse ... passed
> Test: tin_parse ... passed
> Test: polyhedralsurface_parse ... passed
> Test: tin_tgeom ... passed
> Test: psurface_tgeom ... passed
> Test: surface_dimension ... passed
> Test: surface_perimeter ... passed
> Suite: Geodetic Suite
> Test: test_signum ... passed
> Test: test_gbox_from_spherical_coordinates ... passed
> Test: test_gserialized_get_gbox_geocentric ... passed
> Test: test_clairaut ... passed
> Test: test_edge_intersection ... passed
> Test: test_edge_distance_to_point ... passed
> Test: test_edge_distance_to_edge ... passed
> Test: test_lwgeom_distance_sphere ... passed
> Test: test_lwgeom_check_geodetic ... passed
> Test: test_gbox_calculation ... passed
> Test: test_gserialized_from_lwgeom ... passed
> Test: test_spheroid_distance ... passed
> Test: test_spheroid_area ... passed
> Test: test_lwpoly_covers_point2d ... passed
> Test: test_ptarray_point_in_ring ... passed
> Suite: Homogenize Suite
> Test: test_coll_point ... passed
> Test: test_coll_line ... passed
> Test: test_coll_poly ... passed
> Test: test_coll_coll ... passed
> Test: test_geom ... passed
> Suite: GML Out Suite
> Test: out_gml_test_precision ... passed
> Test: out_gml_test_srid ... passed
> Test: out_gml_test_dims ... passed
> Test: out_gml_test_geodetic ... passed
> Test: out_gml_test_geoms ... passed
> Test: out_gml_test_geoms_prefix ... passed
> Test: out_gml_test_geoms_nodims ... passed
> Suite: KML Out Suite
> Test: out_kml_test_precision ... passed
> Test: out_kml_test_dims ... passed
> Test: out_kml_test_geoms ... passed
> Test: out_kml_test_prefix ... passed
> Suite: GeoJson Out Suite
> Test: out_geojson_test_precision ... passed
> Test: out_geojson_test_dims ... passed
> Test: out_geojson_test_srid ... passed
> Test: out_geojson_test_bbox ... passed
> Test: out_geojson_test_geoms ... passed
> Suite: SVG Out Suite
> Test: out_svg_test_precision ... passed
> Test: out_svg_test_dims ... passed
> Test: out_svg_test_relative ... passed
> Test: out_svg_test_geoms ... passed
> Test: out_svg_test_srid ... passed
> --Run Summary: Type Total Ran Passed Failed
> suites 17 17 n/a 0
> tests 143 143 143 0
> asserts 1229 1229 1229 0
> make[2]: Leaving directory
`<http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/l
iblwgeom/cunit'>
> make[1]: Leaving directory
iblwgeom'>
> ---- Making check in regress
> make[1]: Entering directory
`<http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/r
egress'>
> sed
's,$libdir,<http://office.refractions.net:1500/job/PostGIS-trunk-regression/
ws/build/regress/00-regress-install/lib,g'> ../postgis/postgis.sql >
postgis.sql
> make -C ../postgis REGRESS=1
DESTDIR=<http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/
build/regress/00-regress-install> install
> make[2]: Entering directory
`<http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/p
ostgis'>
> Makefile.pgxs:17: warning: overriding commands for target `install'
> /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:96:
warning: ignoring old commands for target `install'
> Makefile.pgxs:63: warning: overriding commands for target `installdirs'
> /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:143:
warning: ignoring old commands for target `installdirs'
> Makefile.pgxs:82: warning: overriding commands for target `uninstall'
> /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:163:
warning: ignoring old commands for target `uninstall'
> mkdir -p --
<http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/re
gress/00-regress-install/share/contrib/postgis-2.0>
> /bin/sh
/var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/../../config/inst
all-sh -c -m 644 ./../spatial_ref_sys.sql
'<http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/build/r
egress/00-regress-install/share/contrib/postgis-2.0'>
> /bin/sh
all-sh -c -m 644 postgis.sql
> /bin/sh
all-sh -c -m 644 uninstall_postgis.sql
> /bin/sh
all-sh -c -m 644 postgis_upgrade_15_minor.sql
> /bin/sh
all-sh -c -m 644 postgis_upgrade_14_to_15.sql
> /bin/sh
all-sh -c -m 644 postgis_upgrade_13_to_15.sql
> /bin/sh
all-sh -c -m 755 libpostgis-2.0.so.0.0
egress/00-regress-install/lib/postgis-2.0.so'>
ostgis'>
> make -C ../loader REGRESS=1
oader'>
> Makefile:136: warning: overriding commands for target `clean'
> /var/home/buildbot/opt/pgsql/8.3.12/lib/pgxs/src/makefiles/pgxs.mk:209:
warning: ignoring old commands for target `clean'
> /bin/sh
all-sh -c pgsql2shp
gress/00-regress-install/bin>
> /bin/sh
all-sh -c shp2pgsql
oader'>
> Creating spatial db postgis_reg
> TMPDIR is
<http://office.refractions.net:1500/job/PostGIS-trunk-regression/ws/results_
8.3.12_3.2.2_4.7.0>
> PATH is
/var/home/buildbot/opt/pgsql/8.3.12/bin:/usr/local/bin:/bin:/usr/bin:/var/ho
> PostgreSQL 8.3.12 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 4.1.2
20080704 (Red Hat 4.1.2-48)
> Postgis 2.0.0SVN - 2011-03-27 18:06:37
> GEOS: 3.2.2-CAPI-1.6.2
> PROJ: Rel. 4.7.1, 23 September 2009
> Running tests
> loader/Point........................... ok
> loader/PointM............................ ok
> loader/PointZ............................ ok
> loader/MultiPoint............................ ok
> loader/MultiPointM............................ ok
> loader/MultiPointZ............................ ok
> loader/Arc............................ ok
> loader/ArcM............................ ok
> loader/ArcZ............................ ok
> loader/Polygon............................ ok
> loader/PolygonM............................ ok
> loader/PolygonZ............................ ok
> loader/TSTPolygon.......... ok
> loader/TSIPolygon.......... ok
> loader/TSTIPolygon.......... ok
> loader/PointWithSchema..... ok
> loader/NoTransPoint......... ok
> loader/NotReallyMultiPoint.................. ok
> loader/MultiToSinglePoint.......... ok
> loader/ReprojectPts..... failed (wkt test: diff expected obtained:
8.3.12_3.2.2_4.7.0/test_20_diff)>
> loader/ReprojectPtsGeog..... failed (wkt test: diff expected obtained:
8.3.12_3.2.2_4.7.0/test_21_diff)>
> loader/Latin1.... ok
> regress. ok
> regress_index. ok
> regress_index_nulls. ok
> lwgeom_regress. ok
> regress_lrs. ok
> removepoint. ok
> setpoint. ok
> simplify. ok
> snaptogrid. ok
> affine. ok
> measures. ok
> long_xact. ok
> ctors. ok
> sql-mm-serialize. ok
> sql-mm-circularstring. ok
> sql-mm-compoundcurve. ok
> sql-mm-curvepoly. ok
> sql-mm-general. ok
> sql-mm-multicurve. ok
> sql-mm-multisurface. ok
> polyhedralsurface. ok
> polygonize. ok
> out_geometry. ok
> out_geography. ok
> in_gml. ok
> in_kml. ok
> iscollection. ok
> regress_ogc. ok
> regress_ogc_cover. ok
> regress_ogc_prep. ok
> regress_bdpoly. ok
> regress_proj. ok
> regress_management. ok
> dump. ok
> dumppoints. ok
> wmsservers_new. ok
> tickets. failed (diff expected obtained:
8.3.12_3.2.2_4.7.0/test_59_diff)>
> remove_repeated_points. ok
> split. ok
> relate. ok
> hausdorff. ok
> regress_buffer_params. ok
> Run tests: 64
> Failed: 3
> make[1]: *** [check] Error 3
egress'>
> make: *** [check] Error 1
> + mv
8.3.12_3.2.2_4.7.0/regress_log>
<http://office.refractions.net:1500/job/PostGIS-trunk-regression/568/artifac
t/results_8.3.12_3.2.2_4.7.0/install-TRUNK_6974_8.3.12_3.2.2_4.7.0.log>
> ++ psql -l
> ++ grep postgis_reg
> ++ wc -l
> + '[' 0 -gt 0 ']'
> + pgsql1 stop
> ++ find -name 'results*'
> + for d in '`find -name '\''results*'\''`'
> + cd ./results_8.3.12_3.2.2_4.7.0
> ++ grep ERROR ./dumper.dbf ./dumper.err ./dumper.shp ./dumper.shx
./install-TRUNK_6974_8.3.12_3.2.2_4.7.0.log ./loader ./loader.err
./regress-TRUNK_6974_8.3.12_3.2.2_4.7.0.log ./test_20_diff ./test_20_out
./test_21_diff ./test_21_out ./test_59_diff ./test_59_out
> ++ wc -l
> + '[' 12 -gt 0 ']'
> ./dumper.err:WARNING: Could not execute prj query: ERROR: schema "pgreg"
does not exist
> ./test_59_out:ERROR: AddGeometryColumns() - invalid SRID
> ./test_59_out:ERROR: lwgeom_to_gml2: 'CurvePolygon' geometry type not
supported
> ./test_59_out:ERROR: lwgeom_longitude_shift: unsupported geom type:
CircularString
> ./test_59_out:ERROR: Unsupported geometry type: CircularString
> ./test_59_out:ERROR: Geometry argument does not have an 'M' ordinate
> ./test_59_out:ERROR: lwgeom_grid: Unsupported geometry type:
CircularString
> ./test_59_out:ERROR: incontinuous compound curve
> ./test_59_out:ERROR: Invalid hex string, length (267) has to be a
multiple of two!
> ./test_59_out:ERROR: Input geometries must be points
> ./test_59_out:ERROR: Shell is not a line
> ./test_59_out:ERROR: First argument must be a LINESTRING
> + exit 1
> Archiving artifacts
Jeff Adams
Azavea | 340 N 12th St, Ste 402, Philadelphia, PA
jadams at azavea.com | T 215.701.7717 | F 215.925.2663
Web azavea.com <http://azavea.com/> | Blog azavea.com/blogs | Twitter
@azavea <http://twitter.com/azavea>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110328/5aa3a19e/attachment.html>
