[postgis-devel] [PostGIS] #942: ST_ModEdgeHeal : test not connected edge
trac at osgeo.org
Fri May 6 12:17:19 PDT 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
testing
select topology.ST_ModEdgeHeal('topo_test',1, 5);
where 1 and 5 are two not directly connected edge (there are an edge #2
between).
the response is:
ERROR: TopoGeom 7 in layer 1 (topo_test.linee_topo.topo_geom) cannot be
represented healing edges 1 and 5
ISO suggest this message:
"SQL/MM Spatial exception – Nonconnected edges"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/942>
