[postgis-devel] [PostGIS] #942: ST_ModEdgeHeal : test not connected edge
trac at osgeo.org
Fri May 6 14:39:15 PDT 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Changes (by strk):
* status: new => assigned
Old description:
> Hi,
> testing
> select topology.ST_ModEdgeHeal('topo_test',1, 5);
> where 1 and 5 are two not directly connected edge (there are an edge #2
> between).
> the response is:
> ERROR: TopoGeom 7 in layer 1 (topo_test.linee_topo.topo_geom) cannot be
> represented healing edges 1 and 5
> ISO suggest this message:
> "SQL/MM Spatial exception – Nonconnected edges"
New description:
testing
where 1 and 5 are two not directly connected edge (there is an edge in
between).
the response is:
Ticket URL: <http://trac.osgeo.org/postgis/ticket/942#comment:1>
