[postgis-devel] [PostGIS] #943: ST_ModEdgeHeal : seem don't working
trac at osgeo.org
Fri May 6 12:26:08 PDT 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
I try this
select topology.ST_ModEdgeHeal('topo_test',17, 16);
where 16 & 17 are two connected edges.
I guess they must heal, but
instead i have this response:
ERROR: TopoGeom 2 in layer 1 (topo_test.linee_topo.topo_geom) cannot be
represented healing edges 17 and 16
I attach the image of the relation between these edges.
The red node are first and last node of the edges.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/943>
