[postgis-devel] [PostGIS] #943: ST_ModEdgeHeal : seem don't working
trac at osgeo.org
Fri May 6 14:28:37 PDT 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Comment(by strk):
Check out this geometry:
SELECT topology.geometry(topo_geom) from topo_test.linee_topo where
id(topo_geom) = 2;
The message says that it is formed by only one of the two edges you're
trying to heal.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/943#comment:1>
