[postgis-devel] [PostGIS] #937: Regression: can't dump POLYGON with EMPTY shell
trac at osgeo.org
Thu May 12 13:46:04 PDT 2011
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by pramsey):
Rather than adding another semantic for EMPTY WKB polygons, can we morph
this case into the "standard" WKB representation for that case, namely, a
polygon with a ring count of zero and nothing else? (Would do this by
having this case return "true" in the lwgeom_is_empty() function).
Incidentally, does the wkb_in code handle the one-empty-ring case
correctly (construct an empty polygon?)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/937#comment:7>
