[postgis-devel] [PostGIS] #937: Regression: can't dump POLYGON with EMPTY shell
trac at osgeo.org
Fri May 13 00:09:08 PDT 2011
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by strk):
Morph how ? Automatically on parsing ? Explicitly on request ?
Note that the bug is about _dumping_, not parsing.
You want to dump something different than you read ?
coliver had an ST_Homogenize code laying around somewhere, such morph
could be undertaken by that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/937#comment:8>
